[GRASS-dev] i.landsat.toar on MSS5 scene
Nikos Alexandris
nik at nikosalexandris.net
Thu Nov 27 01:21:39 PST 2014
I dowloaded the scene the Landsat5 MSS scene LM50160351987287AAA03.
After importing in a utm_z17n based Location, the bands are listed as
B1, B2, B3 and B4.
Running i.landsat.toar fails:
i.landsat.toar -r input_prefix=B output_prefix=Rad.
metfile=LM50160351987287AAA03_MTL.txt
Writing radiance of <B4> to <Rad.4>...
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
ERROR: Unable to open header file for raster map <B5@>
Looking at
<http://landsat.usgs.gov/band_designations_landsat_satellites.php> for
Landsat Multispectral Scanner (MSS), the numbering of bands is right.
Running i.landsat.toar using the -n flag, does the conversion. Kind
of. The output suffix addition, though, follows the band numbering
scheme for MSS1-3, that is 4, 5, 6 and 7. Plus, the The output range
for bands "5", "6", and "7" is nan!.
Even by using the additional parameter sensor=mss5 doesn't solve it
(which is likely overriden if a "metfile" is fed). So, the module
expects for *any* MSS scene the band numbering 4, 5, 6 and 7.
Unless I overlook something, this should be modified to adhere to the
official naming pattern and expect 1, 2, 3, 4 for MSS4,5. Maybe this
will get the "right" bands to perform the conversion correctly?
Nikos
