[GRASS-dev] t.rast.neighbors not working
Sören Gebbert soerengebbert at googlemail.com
Thu Nov 27 02:51:45 PST 2014
Hi Luca,
thanks for the report. Your solution is correct, the bug should be
fixed in r63184/trunk.
I will backport the changes to grass70 as well.
Best regards
Soeren
2014-11-27 11:41 GMT+01:00 Luca Delucchi <lucadeluge at gmail.com>:
> Hi devs,
> I'm working on temporal documentation replacing the example with the
> future temporal dataset that I'm working on, so I'm testing more or
> less all the command.
> I'm not able to run t.rast.neighbors for this problem
> t.rast.neighbors input=tempmean_monthly output=smooth_tempmean_monthly
> base=tmean_smooth size=5 method=average nprocs=4
> ERROR: Space time raster dataset <tempmean_monthly> is already in the
> database. Use the overwrite flag.
> I looked inside t.rast.neighbors source code and I found this line
> new_sp = tgis.check_new_stds(input, "strds", dbif=dbif, overwrite=overwrite)
> probably should be replaced with (I tried and it seems to work)
> new_sp = tgis.check_new_stds(output, "strds", dbif=dbif, overwrite=overwrite)
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
