[GRASS-dev] G7: turning manual page examples into test cases
Vaclav Petras
wenzeslaus at gmail.com
Thu Nov 27 06:18:48 PST 2014
On Thu, Nov 27, 2014 at 8:19 AM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> The next problem is how to distinguish between a module/shell-command
> and the generated output in the manual page? I have plenty of examples
> in the temporal module manual pages that provide the stdout/stderr
> output of the called module in the code section.
> Hence, it would be meaningful to mark code section in the manual page
> that can be used for testing purposes.
I agree with more markup in manual pages for these purposes. Either
different class or some HTML5 tag.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141127/e320170b/attachment.html>
