[GRASS-dev] temporal framework currently not working on windows
Pietro
peter.zamb at gmail.com
Thu Nov 27 06:49:12 PST 2014
Hi Sören,
On Thu, Nov 27, 2014 at 11:38 AM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> My solution would be to remove the function decorator code using the
> most simple approach to add debug messages to the module interface:
> Instead of a function decorator we place this code snippet in the
> function that should emit a debug message.
> from grass.pygrass.messages import get_msgr
> get_msgr().debug(1, self.get_bash())
> What do you think?
> Pietro do you have any objections ... or does my approach does not
> solve the problem?
No objections from my side.
I'm going to remove the decorator.
Pietro
