[GRASS-dev] temporal framework currently not working on windows
Pietro
peter.zamb at gmail.com
Thu Nov 27 07:03:18 PST 2014
On Thu, Nov 27, 2014 at 11:38 AM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> The function decorator code is analysed at import time, which is a
> bad idea, since the messaging server process get started at import
> time. This should be avoided on any OS.
I would like to better understand, this point...
Why the decorator must_be_open it seems to work so far?
which is the difference between @must_be_open[0] and @mdebug[1]?
Any Ideas?
Pietro
[0] http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/errors.py
[1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/modules/interface/module.py#L26
