[GRASS-dev] [GRASS-SVN] r62026 - in grass/trunk: display/d.info include/defs lib/display
Glynn Clements
glynn at gclements.plus.com
Thu Nov 27 09:28:51 PST 2014
Markus Neteler wrote:
> > Author: glynn
> > Date: 2014-09-17 15:43:22 -0700 (Wed, 17 Sep 2014)
> > New Revision: 62026
> > Modified:
> > grass/trunk/display/d.info/main.c
> > grass/trunk/include/defs/display.h
> > grass/trunk/lib/display/r_raster.c
> > grass/trunk/lib/display/setup.c
> > Log:
> > Change handling of display frame, graphical clip window
> > Replace D_get_window with D_get_frame
> > Add D_get_clip_window, D_set_clip_window
> > Add D_set_clip_window_to_map_window, D_set_clip_window_to_screen_window
> > Store initial frame size within display library
> > Change D_setup* functions to set graphical clip window
> Should this be backported to relbr7?
If the new behaviour is desirable[1], then yes.
http://lists.osgeo.org/pipermail/grass-dev/2014-September/070851.html
