[GRASS-dev] [GRASS GIS] #2439: g.gui.iclass crashes
trac at osgeo.org
Fri Nov 28 01:18:16 PST 2014
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.iclass, classification, imagery | Platform: Linux
Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:16 mlennert]:
> Replying to [comment:15 madi]:
> > Replying to [comment:14 annakrat]:
> > > Replying to [comment:13 madi]:
> > > > Replying to [comment:11 mmetz]:
> > > > > Replying to [comment:10 annakrat]:
> > > > > > See possible duplicate #2476.
> > > > > worksforme as of r63077. Please test.
> > > > Thank you Markus. I'm still not able to run g.gui.iclass properly.
I don't know if it's related, but when I try to display the map it says
that I haven't specified the name of the maps. Let's see if I can attach a
screen shot
> > > That's related to something different (#2454), please update and try
again, this should be solved.
> > Thank you Anna, yes indeed now this works. The only strange behaviour
that still remains for me is that digitizing polygons, the dotted line (as
far as I remember it used to be blue) that serves as a guide has
disappeared. So now while i digitize a polygon, when I confirm a segment
it turns green, but when i go to the next segment there is no guiding line
until i confirm it green.
> I can confirm this, but for me (in the general digitizer called directly
in the Map Display), but the problem only appears after opening the
settings menu. When I close the digitizer and reopen it, I then see the
green dotted line again.
More info: I can also make the line appear again by simply switching
drawing tools..
Ticket URL: <https://trac.osgeo.org/grass/ticket/2439#comment:17>
