[GRASS-dev] [GRASS GIS] #2439: g.gui.iclass crashes
GRASS GIS trac at osgeo.org
Fri Nov 28 01:04:40 PST 2014
 Reporter:  madi                                   |       Owner:  grass-dev@…
     Type:  defect                                 |      Status:  new
 Priority:  blocker                                |   Milestone:  7.1.0
Component:  wxGUI                                  |     Version:  svn-trunk
 Keywords:  g.gui.iclass, classification, imagery  |    Platform:  Linux
      Cpu:  x86-64                                 |
Comment(by mlennert):
 Replying to [comment:15 madi]:
 > Replying to [comment:14 annakrat]:
 > > Replying to [comment:13 madi]:
 > > > Replying to [comment:11 mmetz]:
 > > > > Replying to [comment:10 annakrat]:
 > > > > > See possible duplicate #2476.
 > > > > worksforme as of r63077. Please test.
 > > > Thank you Markus. I'm still not able to run g.gui.iclass properly. I
 don't know if it's related, but when I try to display the map it says that
 I haven't specified the name of the maps. Let's see if I can attach a
 screen shot
 > > That's related to something different (#2454), please update and try
 again, this should be solved.
 > Thank you Anna, yes indeed now this works. The only strange behaviour
 that still remains for me is that digitizing polygons, the dotted line (as
 far as I remember it used to be blue) that serves as a guide has
 disappeared. So now while i digitize a polygon, when I confirm a segment
 it turns green, but when i go to the next segment there is no guiding line
 until i confirm it green.
 I can confirm this, but for me (in the general digitizer called directly
 in the Map Display), but the problem only appears after opening the
 settings menu. When I close the digitizer and reopen it, I then see the
 green dotted line again.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2439#comment:16>
