[GRASS-dev] r.out.vtk problem?
Sören Gebbert soerengebbert at googlemail.com
Fri Nov 28 05:35:06 PST 2014
Hi Luca,
can you please provide the command line that produces the wrong output?
Important to know is that r.out.vtk does not transform the GRASS color
table into a VTK lookup table. Therefore you do not see the colors
from GRASS in ParaView.
Best regards
Soeren
2014-11-28 14:28 GMT+01:00 Luca Delucchi <lucadeluge at gmail.com>:
> Hi devs,
> I'm trying to use t.rast.out.vtk but I obtain something strange. I
> think something is wrong with r.out.vtk, I maybe found two errors:
> - it doesn't maintain the color of the map
> - there is something doesn't work with the Z axis.
> I attach two screenshot, problem.png is the paraview scene and
> right.png is the right color of my map.
> I also tested r.out.vtk but I obtain the same result :-(
> Thanks
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
