[GRASS-dev] r.out.vtk problem?
Luca Delucchi lucadeluge at gmail.com
Fri Nov 28 06:28:23 PST 2014
On 28 November 2014 at 14:35, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi Luca,
Hi Soeren
> can you please provide the command line that produces the wrong output?
r.out.vtk in=2012_01_tempmean
out=/tmp/export_temporal/2012_01_tempmean.vtk rgbmaps=2012_01_tempmean
elevation2d=elev_state_500m at PERMANENT
using the data of FOSS4g 2014 temporal workshop
> Important to know is that r.out.vtk does not transform the GRASS color
> table into a VTK lookup table. Therefore you do not see the colors
> from GRASS in ParaView.
ah, would it be possible to implement it? a new parameter like color?
> Best regards
> Soeren
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
