[GRASS-dev] [GRASS GIS] #2504: Dotted line guiding digitization tool disappeared
GRASS GIS trac at osgeo.org
Fri Nov 28 08:07:40 PST 2014
 Reporter:  madi         |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.1.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  digitizer    |    Platform:  Linux
      Cpu:  Unspecified  |
 This was first reported in the ticket #2439. The dotted line that serves
 as a guide for digitizing, has disappeared with the most recent changes.
 Digitizing a polygon, when I confirm a segment it turns green, but when i
 go to the next segment there is no guiding line until i confirm it.
 (Fedora 20)
 Moritz reports that: "the problem only appears after opening the settings
 menu. When I close the digitizer and reopen it, I then see the green
 dotted line again. " and "I can also make the line appear again by simply
 switching drawing tools".
 But this does not work for me.
 Thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/2504>
