[GRASS-dev] [GRASS GIS] #2409: last call for options keys	consolidation
    trac at osgeo.org
    Fri Nov 28 08:27:00 PST 2014
 Reporter:  martinl               |       Owner:  grass-dev@…
     Type:  task                  |      Status:  new
 Priority:  blocker               |   Milestone:  7.0.0
Component:  Default               |     Version:  unspecified
 Keywords:  standardized options  |    Platform:  Unspecified
      Cpu:  Unspecified           |
Comment(by wenzeslaus):
 Martin and Markus, maybe I should add, just to clarify, that I'm
 definitively in favor of all other changes you are doing such as `dsn ->
 output`, `output_prefix -> output`, `devi -> deviations` and
 `minimumtemperature -> minimum_temperature`. I'm just very uncomfortable
 with changes related to rast/vect/rast3d, what you then imply for 3D
 raster and that you don't consider also module names.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:71>
