[GRASS-dev] r.out.vtk problem?
Luca Delucchi lucadeluge at gmail.com
Fri Nov 28 08:16:39 PST 2014
On 28 November 2014 at 16:40, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi Luca,
Hi Soeren
> 2014-11-28 15:28 GMT+01:00 Luca Delucchi <lucadeluge at gmail.com>:
>> On 28 November 2014 at 14:35, Sören Gebbert
>>> Hi Luca,
>> Hi Soeren
>>> can you please provide the command line that produces the wrong output?
>> r.out.vtk in=2012_01_tempmean
>> out=/tmp/export_temporal/2012_01_tempmean.vtk rgbmaps=2012_01_tempmean
>> elevation2d=elev_state_500m at PERMANENT
> Use the "input" option to specify the raster map that should be
> exported. The "rgbmaps" option expects three maps for red, green and
> blue (satellite image data).
> Please use the "elevation" parameter for elevation maps. The
> elevation2d parameter is a number that specifies the height of the
> whole map if no elevation maps was specified.
Yes, sorry this was one of the test that I did, my first test was running this
elevation=elev_state_500m at PERMANENT
> It is possible to implement. Feel free to do it. :)
> You do not need a new parameter, since the "input" option expects one
> more raster maps. Their color tables must be converted into the VTK
> legacy lookup table format to visualize them in ParaView.
It seems not, at least with the command above I cannot see the right
> Best regards
> Soeren
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
