[GRASS-dev] [GRASS-SVN] r62845 - in grass/trunk/scripts: . d.shadedmap r.shadedmap
Vaclav Petras wenzeslaus at gmail.com
Sat Nov 29 06:43:59 PST 2014
On Sat, Nov 29, 2014 at 9:30 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sat, Nov 29, 2014 at 12:37 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > On Fri, Nov 28, 2014 at 5:40 PM, Michael Barton <Michael.Barton at asu.edu>
> > wrote:
> >> Probably nothing to be done about this since r.shaded.relief goes back a
> >> long time. But a more sensible renaming would have the script now called
> >> r.chaded.relief renamed to simply r.relief. Then the modules that drape
> a
> >> colored map onto a relief map could be called x.shaded.relief,
> >> x.shadedrelief, or something like that.
> > That's an interesting option. I'm not sure if I like it but it's worth
> > exploring. If we go even further we get:
> > r.shaded.relief -> r.relief
> > r.shadedmap -> r.shade
> > d.shadedmap -> d.shade
> ... along with:
> - r.blend
> Yes, I like this list better than the current names of discussed modules.
> So, if you like it, I can like it too and I will change it hopefully soon.
Just to be sure: including r.shaded.relief -> r.relief?
Vaclav
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141129/394a3ffc/attachment.html>
