[GRASS-dev] SVN trunk issue with g.list and g.remove (and solution)
Moritz Lennert
mlennert at club.worldonline.be
Thu Oct 2 01:38:16 PDT 2014
On 01/10/14 22:43, Markus Metz wrote:
> On Tue, Sep 30, 2014 at 8:16 PM, Huidae Cho <grass4u at gmail.com> wrote:
>> Hmm... I "remove"d g.list/g.remove and "rename"d g.mlist/g.mremove. Maybe,
>> there is a better way?
> Did you "remove" or "svn remove"? Same for "rename". I guess you did
> "svn [remove|rename]", and some other people did not "make distclean"
> before "svn up". FWIW, I had no problems with your changes, doing
> "make distclean" before "svn up".
> Whoever compiles GRASS from source and wants the latest and greatest
> (svn up), must clean the source code first with "make distclean"
> before recompiling. This applies to all 4 branches. This is not GRASS
> specific but the way how svn works.
In my case I can confirm Markus M's statement:
make distclean
svn up
worked perfectly...
Moritz
