[GRASS-dev] SVN trunk issue with g.list and g.remove (and solution)
Markus Metz markus.metz.giswork at gmail.com
Thu Oct 2 13:16:45 PDT 2014
On Thu, Oct 2, 2014 at 4:22 PM, Huidae Cho <grass4u at gmail.com> wrote:
> On Wed, Oct 01, 2014 at 05:49:08PM -0400, Vaclav Petras wrote:
>>    On Wed, Oct 1, 2014 at 4:43 PM, Markus Metz
>>    <[1]markus.metz.giswork at gmail.com> wrote:
>>      On Tue, Sep 30, 2014 at 8:16 PM, Huidae Cho <[2]grass4u at gmail.com>
>>      wrote:
>>      > Hmm... I "remove"d g.list/g.remove and "rename"d
>>      g.mlist/g.mremove. Maybe,
>>      > there is a better way?
>>      Did you "remove" or "svn remove"? Same for "rename". I guess you did
>>      "svn [remove|rename]", and some other people did not "make
>>      distclean"
>>      before "svn up". FWIW, I had no problems with your changes, doing
>>      "make distclean" before "svn up".
>>      Whoever compiles GRASS from source and wants the latest and greatest
>>      (svn up), must clean the source code first with "make distclean"
>>      before recompiling. This applies to all 4 branches. This is not
>>      GRASS
>>      specific but the way how svn works.
>>    make distclean or just make clean, this might be it. The message from
>>    SVN was not much helpful, although it changed from the previous
>>    version.
>>    But usually you don't have to do make *clean, so how to know these
>>    things ahead (except for looking at Trac)? I don't know. Or is there
>>    some option in SVN (from the options you are given) to use "theirs all"
>>    as it was in previous SVN version (I don't know which)?
> I guess that when you "svn up", it doesn't clean the OBJ directory in
> the old g.list/g.remove directories and old object files conflict with
> the new source files?
Exactly.
The OBJ directory is not under version control, so svn does not touch
it. That means, svn up can not remove a directory if it contains
anything not under version control, and this can lead to conflicts.
before updating with svn up. This applies to all 4 branches. This is
not GRASS specific but the way how svn works. I did this on different
systems with different svn clients and had no problems.
Markus M
> Huidae
>>      Markus M
>>    > On Tue, Sep 30, 2014 at 1:19 PM, Vaclav Petras
>>    <[3]wenzeslaus at gmail.com> wrote:
>>    >> On Tue, Sep 30, 2014 at 12:02 PM, Markus Neteler
>>    <[4]neteler at osgeo.org>
>>    >> wrote:
>>    >>> On Tue, Sep 30, 2014 at 5:25 PM, Vaclav Petras
>>    <[5]wenzeslaus at gmail.com>
>>    >>> wrote:
>>    >>> > Confirmed, I had to do the same in all copies too some time ago.
>>    SVN is
>>    >>> > not
>>    >>> > really good at renaming and deleting things, it is always
>>    confused and
>>    >>> > I
>>    >>> > really don't understand why I need to do revert.
>>    >>> As this almost never happened, it may have been this specific
>>    commit
>>    >>> being different from others.
>>    >>> Whatever, the solution we have.
>>    >> Oh, now I hope it was not because I recommended some Git-like
>>    procedure to
>>    >> Huidae which is not really what SVN wanted. Anyway, it was easy to
>>    solve
>>    >> although it required manual intervention to automatic builds (at
>>    least the
>>    >> one for tests).
>>    >>> Markus
>>    >> _______________________________________________
>>    >> grass-dev mailing list
>>    >> [6]grass-dev at lists.osgeo.org
>>    >> [7]http://lists.osgeo.org/mailman/listinfo/grass-dev
>>    > [8]grass-dev at lists.osgeo.org
>>    > [9]http://lists.osgeo.org/mailman/listinfo/grass-dev
>> References
>>    1. mailto:markus.metz.giswork at gmail.com
>>    2. mailto:grass4u at gmail.com
>>    3. mailto:wenzeslaus at gmail.com
>>    4. mailto:neteler at osgeo.org
>>    5. mailto:wenzeslaus at gmail.com
>>    6. mailto:grass-dev at lists.osgeo.org
>>    7. http://lists.osgeo.org/mailman/listinfo/grass-dev
>>    8. mailto:grass-dev at lists.osgeo.org
>>    9. http://lists.osgeo.org/mailman/listinfo/grass-dev
