[GRASS-dev] [GRASS GIS] #2454: wxgui: list of db columns only becomes available after entering layer number by hand
trac at osgeo.org
Fri Oct 17 02:57:53 PDT 2014
number by hand
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Keywords: columns list | Platform: Linux
Cpu: Unspecified |
* Load a vector map with attribute table
* In the d.vect dialogue go to the Labels section
* Click on the widget for the list of attribute columns
=> empty (in trunk) or you cannot even open the list (grass64release)
* Go into the layer number text field, erase the layer number (1) and
write the same layer number (1)
=> list is filled with available columns
You can also go into the Selection section and select first -1 as layer
number, then back to 1.
This is on Debian testing with wx 2.8.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2454>
