[GRASS-dev] [GRASS GIS] #2453: Thai characters not displaying correctly in the query results window of Map Display in GRASS 7.0.0beta3 Windows
trac at osgeo.org
Sat Oct 18 05:00:41 PDT 2014
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-releasebranch70
Keywords: Map Display, Asian characters | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by wenzeslaus):
Replying to [comment:2 marisn]:
> Replying to [comment:1 annakrat]:
> > It would be good to get first resolved ticket #2431 because it
simplifies reading data from v.what. I think attribute table manager
assumes utf8 unless you specify encoding in settings. I don't think we
have currently any better solution for attributes encoding, especially
combining data with different encodings.
> DB encoding issues will have to be solved one day. The correct option
would be add a encoding metadata to dblink. Still it needs some design
decisions (should it be enforced?). Unfortunately I had no time to work on
it this year :( and it is too large change for 7.0.
> http://lists.osgeo.org/pipermail/grass-dev/2014-April/068160.html
Sounds reasonable to me. According to your current understanding, do you
think that the change could be done in backwards compatible manner?
Because if not, it would have to wait to 8.0.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2453#comment:3>
