[GRASS-dev] [GRASS GIS] #2451: rendering vector in map display freezes when fonts is changed in GUI options: map display
GRASS GIS trac at osgeo.org
Fri Oct 17 06:44:40 PDT 2014
  Reporter:  hellik       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Display      |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  fonts
  Platform:  MSWindows 7  |         Cpu:  Unspecified
Changes (by annakrat):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:2 mlennert]:
 > Replying to [comment:1 annakrat]:
 > > I tried to fix it in r62269 and backported. The fix assumes there is
 no font with non-ascii characters which might not be always true, I don't
 know.
 > I'm not sure I understand: your fix assumes that there is no font used
 in GRASS with non-ascii characters, or that the issue that Helmut reports
 is due to the use of a font without non-ascii characters ?
 Sorry for the confusing sentence. The limitation of the fix is that the
 font name can't have any non-ascii characters.
 I tested it with latest build, it works.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2451#comment:3>
