[GRASS-dev] Backport r.li memory allocation fixes?
Vaclav Petras
wenzeslaus at gmail.com
Fri Oct 17 09:01:59 PDT 2014
On Wed, Oct 15, 2014 at 1:52 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 15, 2014 at 3:35 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> > Hi Markus and others,
> > I would do a backport or r61812 but I'm not sure if it works correctly.
> It
> > seems to work and I got the same results as with the old version but I
> > remember that you (Markus) had some doubts at one point. Now I actually
> see
> > that you said you will backport it, so if you have your plan disregard
> this
> > message.
> Please backport it. It should probably also go into G6 which is almost
> identical.
> Done for 7.0, not 6.x, maybe some other time, I don't have any 6 on my
computer now.
http://trac.osgeo.org/grass/changeset/62279
> I also wanted to use the things bellow to write a test but I don't know
> how.
> Would this script give some ideas?
> raster/r.li/r.li.testing_nc_asc.sh
Unfortunately not to me, but if you think that this script could be part of
the automatic testing move it to testsuite subdirectory.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141017/043872d9/attachment.html>
