[GRASS-dev] [GRASS GIS] #2452: v.surf.rst option devi Windows problem
GRASS GIS trac at osgeo.org
Tue Oct 21 07:43:06 PDT 2014
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-releasebranch70
 Keywords:  v.surf.rst   |    Platform:  MSWindows 8
      Cpu:  Unspecified  |
Comment(by annakrat):
 Replying to [comment:1 annakrat]:
 > Replying to [ticket:2452 annakrat]:
 > > d.vect had at one point problem to display the vector after the first
 run but I was not able to reproduce it, now it displays fine.
 > d.vect gives this, but not always, sometimes it doesn't complain.
 > WARNING: Size of 'coor' file differs from value saved in topology file
 > WARNING: Please rebuild topology for vector map <elev_rstdef_cv at user1>
 > ERROR: Unable to open topology file for vector map
 Driver was not closed, I fixed that in r62300 (backported in r62322) and
 also added db transaction which speeds up the computation a lot. However,
 there is still the problem with the coor file. Is this something which
 could be related to the driver and fixed by r62300 as well or not? The
 problem is that I couldn't reproduce this problem, it happened only few
 times to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2452#comment:6>
