[GRASS-dev] tests failed
Martin Landa landa.martin at gmail.com
Fri Oct 24 04:05:28 PDT 2014
2014-10-24 12:04 GMT+02:00 Pietro <peter.zamb at gmail.com>:
> However, I would like to revert your change... :-)
> Introduce the debug message in the Module class it is a bad idea
> because in this way also Module class is indirectly using ctypes.
> Therefore all the work done to distinguish and isolate pygrass'
> submodules that are using the ctypes is not valid any more.
well, it's _very_ useful info to know which commands are called on
background. So if you revert it please provide this info somehow in
other way.
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
