[GRASS-dev] v.overlay handles mapname at mapset in a wrong way
Vaclav Petras
wenzeslaus at gmail.com
Fri Oct 24 17:26:06 PDT 2014
Sorry for bothering you with this again but now I'm confused. The test
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-10-22-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.vect.mapcalc/test.t.vect.mapcalc/index.html
is still failing but after explanation by Glynn in
http://trac.osgeo.org/grass/ticket/2437#comment:18
http://trac.osgeo.org/grass/ticket/2437#comment:23
I have no idea what is the right fix. (I had no idea before but now it is
even worse.)
Thanks,
Vaclav
On Wed, Sep 17, 2014 at 6:00 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Sep 17, 2014 at 5:24 PM, Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
>> On Wed, Sep 17, 2014 at 10:28 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>> > On Wed, Sep 17, 2014 at 3:50 PM, Markus Metz <
>> > wrote:
>> >> On Wed, Sep 17, 2014 at 3:33 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> >> wrote:
>> >> > Hi,
>> >> > it seems [1] that v.overlay cannot handle dot in mapset name which
>> >> > probably
>> >> > points to a wrong handling of mapset in a parameter.
>> >> How did you manage to add @<mapset> to the output name? With the GUI
>> >> this is not possible. On the command line you should not add @<mapset>
>> >> to a vector output (this might apply also to raster output, I did not
>> >> check) because output maps are always created in the current mapset.
>> > Oh, I didn't realized that.
>> GRASS is designed for multi-user environments such as research
>> institutions or public administration institutions. A given user has
>> write permissions only to its home directory, /tmp or %TMP% and the
>> current mapset which the current user owns in terms of permissions
>> (dependent on file system and operating system). Any other mapsets are
>> assumed to belong to different users. This has been pointed out
>> repeatedly before and is a security feature. Even if you are the owner
>> of several different mapsets, you are still allowed to create new data
>> only in the current mapset. This is a security feature needed e.g. for
>> HPC (High Performance Computing).
> Considering that you are a GRASS developer you should have realized that.
>> Oh, sorry for confusion. I actually know this. I didn't realized that it
> is output, not input, and so there shouldn't be any mapset at all.
> I was basically just performing the function which the testing framework
> is not yet doing: sending emails about what is broken.
> Thanks for the explanation anyway, I was recently giving one but next time
> I will use yours since it is nicely written. It might and up in the manual
> too.
> Vaclav
>> Markus M
>> > The error is caused by t.vect.mapcalc (visible in tests). It seems that
>> it
>> > is just adding the mapset name there for some reason.
>> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-17-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.vect.mapcalc/test.t.vect.mapcalc/index.html
>> >> The error appears not in the module but in the library, thus affects
>> >> all modules who care to check the validity of a vector output name.
>> >> IOW, the vector output name must not be a fully qualified name. I have
>> >> fixed that in r62023,4 for trunk and relbr_70. The warning is now
>> >> WARNING: Illegal vector map name
>> >> <tmp_map_name_27967_1 at __temporal_t_vect_mapcalc_test.t.vect.mapcalc>.
>> >> Character '@' not allowed.
>> >> because '@' occurs before '.' in the fully qualified name.
>> > This is much clearer message, thanks.
>> > Vaclav
>> >> Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141024/1eb33757/attachment-0001.html>
