[GRASS-dev] v.overlay handles mapname at mapset in a wrong way
    Markus Metz
    markus.metz.giswork at gmail.com
    Sat Oct 25 05:32:00 PDT 2014
On Sat, Oct 25, 2014 at 2:26 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Sorry for bothering you with this again but now I'm confused. The test
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-10-22-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.vect.mapcalc/test.t.vect.mapcalc/index.html
This seems to be a bug either in lib/python/temporal or in
lib/python/pygrass. Somewhere the mapset is appended to the output
name. Output is always created in the current mapset, thus output
names are not allowed to contain '@'. This applies to all GRASS
database elements.
Is it possible that pygrass does not discriminate between opening old
and new vector maps, just like pygrass did not discriminate between
opening old and new raster maps?
Markus M
> is still failing but after explanation by Glynn in
> http://trac.osgeo.org/grass/ticket/2437#comment:18
> http://trac.osgeo.org/grass/ticket/2437#comment:23
> I have no idea what is the right fix. (I had no idea before but now it is
> even worse.)
> Thanks,
> Vaclav
> On Wed, Sep 17, 2014 at 6:00 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Wed, Sep 17, 2014 at 5:24 PM, Markus Metz
>> <markus.metz.giswork at gmail.com> wrote:
>>> On Wed, Sep 17, 2014 at 10:28 PM, Vaclav Petras <wenzeslaus at gmail.com>
>>> wrote:
>>> > On Wed, Sep 17, 2014 at 3:50 PM, Markus Metz
>>> > wrote:
>>> >> On Wed, Sep 17, 2014 at 3:33 PM, Vaclav Petras <wenzeslaus at gmail.com>
>>> >> wrote:
>>> >> > Hi,
>>> >> > it seems [1] that v.overlay cannot handle dot in mapset name which
>>> >> > probably
>>> >> > points to a wrong handling of mapset in a parameter.
>>> >> How did you manage to add @<mapset> to the output name? With the GUI
>>> >> this is not possible. On the command line you should not add @<mapset>
>>> >> to a vector output (this might apply also to raster output, I did not
>>> >> check) because output maps are always created in the current mapset.
>>> > Oh, I didn't realized that.
>>> GRASS is designed for multi-user environments such as research
>>> institutions or public administration institutions. A given user has
>>> write permissions only to its home directory, /tmp or %TMP% and the
>>> current mapset which the current user owns in terms of permissions
>>> (dependent on file system and operating system). Any other mapsets are
>>> assumed to belong to different users. This has been pointed out
>>> repeatedly before and is a security feature. Even if you are the owner
>>> of several different mapsets, you are still allowed to create new data
>>> only in the current mapset. This is a security feature needed e.g. for
>>> HPC (High Performance Computing).
>>> Considering that you are a GRASS developer you should have realized that.
>> Oh, sorry for confusion. I actually know this. I didn't realized that it
>> is output, not input, and so there shouldn't be any mapset at all.
>> I was basically just performing the function which the testing framework
>> is not yet doing: sending emails about what is broken.
>> Thanks for the explanation anyway, I was recently giving one but next time
>> I will use yours since it is nicely written. It might and up in the manual
>> too.
>> Vaclav
>>> Markus M
>>> > The error is caused by t.vect.mapcalc (visible in tests). It seems that
>>> > it
>>> > is just adding the mapset name there for some reason.
>>> > http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-17-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.vect.mapcalc/test.t.vect.mapcalc/index.html
>>> >> The error appears not in the module but in the library, thus affects
>>> >> all modules who care to check the validity of a vector output name.
>>> >> IOW, the vector output name must not be a fully qualified name. I have
>>> >> fixed that in r62023,4 for trunk and relbr_70. The warning is now
>>> >> WARNING: Illegal vector map name
>>> >> <tmp_map_name_27967_1 at __temporal_t_vect_mapcalc_test.t.vect.mapcalc>.
>>> >>          Character '@' not allowed.
>>> >> because '@' occurs before '.' in the fully qualified name.
>>> > This is much clearer message, thanks.
>>> > Vaclav
>>> >> Markus M
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
