[GRASS-dev] No Required GUI section for g.list and g.remove
Moritz Lennert mlennert at club.worldonline.be
Tue Oct 28 10:38:07 PDT 2014
On 28/10/14 16:40, Anna Petrášová wrote:
> On Tue, Oct 28, 2014 at 10:31 AM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
>     On 25/10/14 02:58, Anna Petrášová wrote:
>         Hi,
>         On Tue, Oct 14, 2014 at 11:56 AM, Anna Petrášová
>         <kratochanna at gmail.com <mailto:kratochanna at gmail.com>
>         <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>>__>
>         wrote:
>              Hi,
>              On Tue, Oct 14, 2014 at 8:58 AM, Vaclav Petras
>         <wenzeslaus at gmail.com <mailto:wenzeslaus at gmail.com>
>         <mailto:wenzeslaus at gmail.com>>> wrote:
>                  On Tue, Oct 14, 2014 at 5:28 AM, Moritz Lennert
>                  <mailto:mlennert at club.__worldonline.be
>         <mailto:mlennert at club.worldonline.be>>> wrote:
>                      On 14/10/14 10:38, Paulo van Breugel wrote:
>                          On Tue, Oct 14, 2014 at 10:06 AM, Moritz Lennert
>         <mailto:mlennert at club.>__worldo__nline.be <http://worldonline.be>
>         <mailto:mlennert at club.worldonline.be>>>> wrote:
>                               On 14/10/14 09:14, Paulo van Breugel wrote:
>                                   Putting the 'ignore' option in
>         separate tab
>                          with patterns is fine I
>                                   think. Also, for g.remove to have the
>         'type'
>                          and 'name' together
>                                   in one
>                                   tab is also a good idea imho.
>                                   I am not sure I understand the last
>         question;
>                          you mean to add the
>                                   possibility to make an option required but
>                          still have the option
>                                   to put
>                                   it in another section? I think that
>         would be a
>                          good idea, not
>                                   only in
>                                   this case, but more in general, it
>         would make
>                          it easier to create an
>                                   consistent interface for modules that
>         require
>                          more than a few
>                                   inputs.
>                                   It might be a good idea to flag options as
>                          required, e.g., by adding
>                                   '(required)' after the option name?
>                               I'm not sure I agree with this as this
>         would leave
>                          the door open for
>                               required flags to be disseminated across
>         several
>                          sections. I like
>                               the fact that the use immediately sees what is
>                          required to run the
>                               module.
>                          I guess it is a matter of preference. There are
>         some
>                          grey area or cases
>                          where this separate 'required' tab does not
>         really work
>                          i.m.h.o.
>                          The '-f' flag in g.remove is one example. You
>         can run
>                          the module without
>                          (so it shouldn't go in the 'required' tab), but you
>                          can't do what the
>                          module is basically meant to do without it,
>         which is
>                          removing layers (so
>                          in that sense it should be a required choice).
>                          Perhaps a better example is r.random. One of the
>                          required options is the
>                          output layer. That can be a raster layer, a
>         vector layer
>                          or both.
>                          Because of this construct, the required output name
>                          cannot be marked as
>                          required. Solution is to use a separate tab
>         'optional'
>                          where the user
>                          can provide the output name of the vector,
>         raster or
>                          both layers. So the
>                          user has to fill in required information in a
>         'required
>                          tab' and an
>                          'optional' tab. I don't think it is really
>         problematic
>                          as failing to
>                          give the output name results in a clear error
>         message,
>                          but it isn't
>                          exactly consistent.
>                      The new options to declare parameters as mutually
>         exclusive
>                      or as "at least one is requried of the group" might
>         be a
>                      solution to that, but no idea how to implement this
>         in the GUI.
>                  Put this to GUI is certainly needed but challenging and
>         I it
>                  will not be included in 7.0. Perhaps we should put this
>         to the
>                  manual in some way. But modules are not using it anyway.
>                  Anyway, these "at least one required" are causing Required
>                  section to be less and less used, so that's another
>         reason why
>                  it makes sense to leave it out sometimes.
>              I think it makes thanks to 'override' the required property
>         with the
>              guisection. If we do it for a module, we should make sure
>         there is
>              no Required tab at all. I think having required parameters
>         in custom
>              tabs and eliminate Required tab is totally fine. Having
>         Required tab
>              and at the same time have required parameters in other sections
>              would not work well.
>              Also we could mark the required options in the gui somehow, for
>              example add a red star? In the code I see attempts to
>         render the
>              labels as bold, it is not used eventually, but I don't
>         think bold is
>              the best way anyway.
>         I attached screenshots with using the red star for required
>         options (and
>         in this case I was also testing when the guisection is preferred to
>         required). In my opinion, it gives you good idea what is required or
>         not. There are some problems coming from the wxPython
>         limitations, for
>         example the one which you see on the second screenshot: when the
>         label
>         is part of the border, I can't set the asterisk red, the color
>         can be
>         changed only for the entire label. But for majority options, it
>         works.
>         Regarding the required vs. guisection, I really think we should
>         try to
>         organize the options logically, not based on required/optional. Some
>         distinction of the required options is then needed and the red
>         asterisk
>         seems to be a good solution. But we can discuss some other
>         options too,
>         of course.
>     If you really want to go down that path (it would get a 0 from me),
>     then please remove the required tab completely. It will be very
>     confusing to have a required section, but not with all required
>     parameters in it.
>     I personally like the way the required tab focuses attention on the
>     most important parameters, even though I do understand that there
>     are ambiguities that this system creates. I'm not sure, though, that
>     getting rid of the required tab is the solution. But if you go in
>     that direction it should be all the way.
> Well, there are already modules which already don't have required tab
> (r.colors, many t.* modules). Also a lot of modules have required tab
> but it is more confusing than helpful. Do you require to remove Required
> tab from all the modules? Even from modules where it still makes sense?
> Or you are talking about the case when the option is required but the
> guisection is specified, so it would get into a different tab? For the
> first option, we would have to go through all modules (several hundreds)
> and come up with some substitute, that's not feasible.
No, I agree with what Vaclav said: for those modules where required
options are all in the required section, this should stay. However, if
in a module you put required parameters in other sections, then there
should be no more required section for that module.
Moritz
