[GRASS-dev] wxpython 3 and errors in grass
Michael Barton
Michael.Barton at asu.edu
Thu Oct 30 15:20:48 PDT 2014
Maybe William has this built into his bundling code. When I compile and then create a Mac binary, I specify which wx I am using by pointing to a specific wx_config. We then bundle all wxPython code into the binary *.app and GRASS uses that, whatever wx is on the user’s system. Perhaps you can’t do something similar in Linux.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Oct 30, 2014, at 3:14 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> At least for me, it is possible to have multiple versions of wx
>> installed. The important thing is which you use when you compile
>> GRASS�determined by the path to wx_config
> The only module which is affected by wx-config is
> visualisation/wximgview (which has probably been superseded by
> scripts/wxpyimgview).
> Anything written in Python will use the wxPython version found by the
> Python import mechanism and the wxversion module.
> If the code doesn't use wxversion, it will use whichever version
> site-packages/wx.pth refers to.
