[GRASS-dev] wxpython 3 and errors in grass
William Kyngesburye woklist at kyngchaos.com
Thu Oct 30 15:44:54 PDT 2014
There is a GRASS_WXBUNDLED var (set in the OS X grass.sh) that globalvar.py checks for, to avoid the CheckForWx() call, and it's wxversion stuff.  I think the problem was that the bundled wxpython would be ignored, even though it was before another installed wxpython in the search path, something to do with the wxversion mechanism for selecting a version.
On Oct 30, 2014, at 5:20 PM, Michael Barton <michael.barton at asu.edu> wrote:
> Maybe William has this built into his bundling code. When I compile and then create a Mac binary, I specify which wx I am using by pointing to a specific wx_config. We then bundle all wxPython code into the binary *.app and GRASS uses that, whatever wx is on the user’s system. Perhaps you can’t do something similar in Linux.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 	480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> www: 	http://csdc.asu.edu, http://shesc.asu.edu
> 		http://www.public.asu.edu/~cmbarton
> On Oct 30, 2014, at 3:14 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
>> Michael Barton wrote:
>>> At least for me, it is possible to have multiple versions of wx
>>> installed. The important thing is which you use when you compile
>>> GRASS�determined by the path to wx_config
>> The only module which is affected by wx-config is
>> visualisation/wximgview (which has probably been superseded by
>> scripts/wxpyimgview).
>> Anything written in Python will use the wxPython version found by the
>> Python import mechanism and the wxversion module.
>> If the code doesn't use wxversion, it will use whichever version
>> site-packages/wx.pth refers to.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
