[GRASS-dev] Is not it possible to use GRASS-GIS through command line access?
Maris Nartiss
maris.gis at gmail.com
Fri Oct 31 01:31:22 PDT 2014
Did you start GRASS session before executing i.cluster? GRASS modules
should not be run outside of GRASS working session (see Wiki how to
set up necessary environmental variables to run modules outside of
working session).
Maris.
PS. This should better be posted in -user ML.
2014-10-30 23:59 GMT+02:00 Artur Bercik <vbubbly21 at gmail.com>:
> Dear GRASS-GIS developers:
> I wanted to use GRASS-GIS through command line access in my Windows PC.
> So, I have installed GRASS GIS 7.0.0beta3 in drive C of my PC.
> But, when I enter the following command in the windows command prompt:
> "C:\Program Files (x86)\GRASS GIS 7.0.0beta3\bin\i.cluster.exe"
> I got the following error message:
> The program can't start because libint-8.dll is missing from your computer.
> Try reinstalling the program...
> Please help me what should I do to have the command line access to
> GRASS-GIS.
> I hope someone can help me.
> Your quick response is highly appreciated.
> Thanks in the advance,
> Artur
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
