[GRASS-dev] Is not it possible to use GRASS-GIS through command line access?
Vaclav Petras
wenzeslaus at gmail.com
Fri Oct 31 07:57:20 PDT 2014
On Fri, Oct 31, 2014 at 4:31 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> PS. This should better be posted in -user ML.
It actually was, the discussion is there.
http://lists.osgeo.org/pipermail/grass-user/2014-October/071164.html
http://osgeo-org.1560.x6.nabble.com/Unable-to-use-Command-Line-Access-to-GRASS-GIS-td5170492.html
https://gis.stackexchange.com/questions/120433/is-not-it-possible-to-use-grass-gis-through-command-line-access
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141031/529bec84/attachment.html>
