[GRASS-dev] How to check if a vector map is multi-layer?
Markus Metz markus.metz.giswork at gmail.com
Fri Oct 31 01:34:31 PDT 2014
On Thu, Oct 30, 2014 at 3:23 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 30 October 2014 15:08, Markus Metz <markus.metz.giswork at gmail.com> wrote:
>> On Thu, Oct 30, 2014 at 2:31 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>>> Hi Markus,
>>> On 29 October 2014 09:15, Markus Metz <markus.metz.giswork at gmail.com> wrote:
>>>> Please try the attached patch for gui/wxpython/rlisetup.
>>> I test your patch and it works. I improved a little bit it (attached
>>> the new patch).
>> Why did you remove the part that removes duplicates? This is needed in
>> order to avoid that the same raster is created twice, independent of
>> whether a feature has multiple categories or not (different features
>> can have the same category).
> I only move it to a function because it is used more than one, and
> change the for loop with a single line code [ sorted(set(list))  this
> is what I usually use in Python to remove duplicate from list ]
Oops, I did not notice the set(), sorry!
>> The description of the new function obtainCategories() is wrong. The
>> function does not check whether a vector is multilayer. The function
>> does not even check whether a feature has multiple categories in a
>> given layer. The function returns a list of all categories in layer X
>> for type=centroid which is what you want for g.gui.rlisetup.
> ok, could you fix the description with the right sentence?
See attached patch.
>> Actually,
>> g.gui.lisetup does not care about the vector layer, which is another
>> bug. And it does not care about the vector type. You should add the
>> options layer= and type= wherever appropriate.
> You are right, for the type we could add a check when the user select
> the vector, only vector with areas should be accepted.
I have added type= where it was missing.
> For the layer I don't know what could be the right solution, maybe
> another combobox to select the layer to use?
Yes, or fix it to layer 1. I have added a layer option to the relevant
functions in functions.py, right now fixed to 1.
You can submit the attached patch if it works for you.
Markus M
>> Markus M
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141031/9201aca2/attachment-0001.obj>
