[GRASS-dev] G7 blockers call
Helmut Kudrnovsky hellik at web.de
Fri Sep 5 13:17:29 PDT 2014
>>But doing the steps from the
>> installer manually works (the third suggestion). This was the case on
>> two (or more) computers already.
>I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
>Installing with admin priviliges and checking the box for the MS runtime
>environments didn't help but copying the DLLs manually to extrabin did
>the trick (as suggested in [1]).
which windows version (7, 8)? any antivirus software?
the winGRASS standalone installer should copy the DLLs to extrabin, see
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl#L943
943	        CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll"
"$INSTDIR\extrabin"
more informations and investigations are needed ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5160427.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
