[GRASS-dev] Tests down to 58% (from 81%)
Vaclav Petras
wenzeslaus at gmail.com
Fri Sep 5 14:36:27 PDT 2014
On Fri, Sep 5, 2014 at 4:18 PM, Sören Gebbert <soerengebbert at googlemail.com>
wrote:
> I have hopefully fixed the issues that caused the failure of tests in
> r61806 and added some additional shell test files to the testsuite in
> r61807.
> Great thanks, we can check tomorrow.
> Regarding the tests, can you please install python-ply (PLY[1] package
> for temporal algebra lex and yacc parser) at the test server, so that
> the temporal algebra tests will work, at least most of them?
> Let me wait with this for tomorrow, so we can see what was improved.
> Best regards
> Soeren
> [1] http://www.dabeaz.com/ply/
> 2014-09-04 21:27 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
> > 2014-09-04 16:43 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> >> Hi,
> >> just to let you know in case you haven't noticed, something between
> r61753
> >> and 61763 broke a lot of temporal tests.
> > Oh, no. I will try to investigate this. Thank you for checking this.
> > Soeren
> >> Vaclav
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-08-27-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-08-28-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140905/ce56fd6a/attachment.html>
