[GRASS-dev] Tests down to 58% (from 81%)
Vaclav Petras
wenzeslaus at gmail.com
Sat Sep 6 08:42:40 PDT 2014
On Fri, Sep 5, 2014 at 5:36 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Fri, Sep 5, 2014 at 4:18 PM, Sören Gebbert <
> soerengebbert at googlemail.com> wrote:
>> I have hopefully fixed the issues that caused the failure of tests in
>> r61806 and added some additional shell test files to the testsuite in
>> r61807.
>> Great thanks, we can check tomorrow.
Tests are at 86% successful test files.
There is a problem with t.rast.to.rast3.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-06-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.rast3/test_strds_to_rast3/index.html
Perhaps a missing region settings.
> Regarding the tests, can you please install python-ply (PLY[1] package
>> for temporal algebra lex and yacc parser) at the test server, so that
>> the temporal algebra tests will work, at least most of them?
>> Let me wait with this for tomorrow, so we can see what was improved.
Installed, so let's see tomorrow.
> Best regards
>> Soeren
>> [1] http://www.dabeaz.com/ply/
>> 2014-09-04 21:27 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
>> > 2014-09-04 16:43 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
>> >> Hi,
>> >> just to let you know in case you haven't noticed, something between
>> r61753
>> >> and 61763 broke a lot of temporal tests.
>> > Oh, no. I will try to investigate this. Thank you for checking this.
>> > Soeren
>> >> Vaclav
>> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-08-27-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
>> http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-08-28-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140906/4d60d16e/attachment.html>
