[GRASS-dev] G7 blockers call
Johannes Brauner
johannes.brauner at tu-dresden.de
Sat Sep 6 13:04:19 PDT 2014
On 05.09.2014 23:57, Anna Petrášová wrote:
> On Fri, Sep 5, 2014 at 4:17 PM, Helmut Kudrnovsky <hellik at web.de
> <mailto:hellik at web.de>> wrote:
> >>But doing the steps from the
> >> installer manually works (the third suggestion). This was the case on
> >> two (or more) computers already.
> >I can confirm this behavior for WinGRASS-7.0.0svn-r61783-1071.
> >Installing with admin priviliges and checking the box for the MS runtime
> >environments didn't help but copying the DLLs manually to extrabin did
> >the trick (as suggested in [1]).
> which windows version (7, 8)? any antivirus software?
> I saw the problem with both versions. I can't check the antivirus now
> but that might be causing it.
Cannot check for Windows 8, just for 7 64bit. I'm using Microsoft
Security Essentials but it makes no difference whether it's enabled or
not. No luck even with forced administrative privileges during setup
and/or runtime. Also just checked with the newest build
(WinGRASS-7.0.0svn-r61811-1073).
I've however multiple copies of msvcr71.dll installed on my system with
the one in C:\Windows\Microsoft.NET\Framework\v1.1.4322\msvcr71.dll
being most relevant I assume.
Copying them manually in extrabin still does the trick.
Cheers,
Johannes
> the winGRASS standalone installer should copy the DLLs to extrabin, see
> the dlls are not there although the installation seems to finish correctly
> Anna
> http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl#L943
> 943 CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll"
> "$INSTDIR\extrabin"
> more informations and investigations are needed ...
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/G7-blockers-call-tp5157820p5160427.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140906/0e19ab9b/attachment.pgp>
