[GRASS-dev] does r.composite respect a mask?
Tue Sep 9 08:34:45 PDT 2014
Michael Barton wrote:
> It is taking a VERY long time to run r.composite. It is a big map in
> its entirety. But only a part of the map falls within the MASK.
> FWIW, I have the computational region set to match the MASK too.
r.composite doesn't do anything special with regard to the region or
mask.
A "sparse" map (with large null areas) should have some advantage over
a dense map, as the colour lookup optimises the case where a cell's
value matches the previous cell's value, and also checks for null
before other values.
