[GRASS-dev] [GRASS GIS] #2407: Rename i.tasscap to i.landsat.tasscap?
GRASS GIS trac at osgeo.org
Fri Sep 12 09:10:45 PDT 2014
  Reporter:  jbrauner  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  blocker   |   Milestone:  7.0.0
 Component:  Imagery   |     Version:  svn-releasebranch70
Resolution:  fixed     |    Keywords:  i.tasscap, landsat
  Platform:  All       |         Cpu:  All
Comment(by wenzeslaus):
 Replying to [comment:4 jbrauner]:
 > Side note: I'm not sure if a new (even blocking?) ticket is required,
 asking for these new parameters like 'sensor' to be foreseen in the future
 - I'm just wondering because of the upcoming RC. I'm also guessing that a
 number of other parameters could change as well. Certainly not my decision
 to make :)
 I'm not following this issue but in general blocker is required only if
 the API is changed in backwards incompatible manner. So, if you are adding
 parameter but it has a default which gives the equivalent result as the
 previous version it is OK.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2407#comment:5>
