[GRASS-dev] [GRASS GIS] #2407: Rename i.tasscap to i.landsat.tasscap?
trac at osgeo.org
Fri Sep 12 11:10:58 PDT 2014
Reporter: jbrauner | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 7.0.0
Component: Imagery | Version: svn-releasebranch70
Resolution: fixed | Keywords: i.tasscap, landsat
Platform: All | Cpu: All
Comment(by jbrauner):
Replying to [comment:5 wenzeslaus]:
> Replying to [comment:4 jbrauner]:
> > Side note: I'm not sure if a new (even blocking?) ticket is required,
asking for these new parameters like 'sensor' to be foreseen in the future
- I'm just wondering because of the upcoming RC. I'm also guessing that a
number of other parameters could change as well. Certainly not my decision
to make :)
> I'm not following this issue but in general blocker is required only if
the API is changed in backwards incompatible manner. So, if you are adding
parameter but it has a default which gives the equivalent result as the
previous version it is OK.
Oh, I see, thanks a lot for the clarification.
Cheers,
Johannes
Ticket URL: <http://trac.osgeo.org/grass/ticket/2407#comment:6>
