[GRASS-dev] [GRASS GIS] #2407: Rename i.tasscap to i.landsat.tasscap?
trac at osgeo.org
Fri Sep 12 14:42:48 PDT 2014
Reporter: jbrauner | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: Imagery | Version: svn-releasebranch70
Resolution: | Keywords: i.tasscap, landsat
Platform: All | Cpu: All
Changes (by neteler):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:5 wenzeslaus]:
> I'm not following this issue but in general blocker is required only if
the API is changed in backwards incompatible manner.
Yes: In this case the actual flags need to be turned into values for the
new sensor= parameter.
(see http://grass.osgeo.org/grass70/manuals/i.tasscap.html):
sensor=landsat4,landsat5,landsat7,landsat8,quickbird,...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2407#comment:7>
