[GRASS-dev] [GRASS GIS] #2407: Rename i.tasscap to i.landsat.tasscap?
trac at osgeo.org
Sat Sep 13 15:07:24 PDT 2014
Reporter: jbrauner | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: Imagery | Version: svn-releasebranch70
Resolution: | Keywords: i.tasscap, landsat
Platform: All | Cpu: All
Comment(by wenzeslaus):
Replying to [comment:7 neteler]:
> Replying to [comment:5 wenzeslaus]:
> > I'm not following this issue but in general blocker is required only
if the API is changed in backwards incompatible manner.
> Yes: In this case the actual flags need to be turned into values for the
new sensor= parameter.
> (see http://grass.osgeo.org/grass70/manuals/i.tasscap.html):
> sensor=landsat4,landsat5,landsat7,landsat8,quickbird,...
The new version committed in r61920 to trunk has `satellite` option
instead of flags and one `input` option instead of several `band*`
options.
Several naming changes done with MarkusN in order to be more precise about
satellite/sensor. Feedback welcome, especially the manual page should be
reviewed. I tested that but more testing would be helpful too.
Now it is possible to add new satellites/sensors easily without breaking
API.
This ticket can be closed once the change is backported to 7.0.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2407#comment:8>
