[GRASS-dev] [GRASS GIS] #2417: r.profile should report distance in location units
trac at osgeo.org
Mon Sep 15 01:05:41 PDT 2014
Reporter: annakrat | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Projections/Datums | Version: svn-trunk
Keywords: r.profile, units | Platform: All
Cpu: Unspecified |
Comment(by mlennert):
Replying to [ticket:2417 annakrat]:
> r.profile reports the length in meters no matter which units the current
location uses. It would be better if it could report it in the current
units.
The attached patch is a very simple attempt to use location units. I don't
have time right now to revert the GUI profile tool changes to check
whether this solves the problem, but at least with this patch distances
are in location units.
The question is whether this should be the default behaviour of r.profile,
or whether this should be only activated when a flag is set.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2417#comment:1>
