[GRASS-dev] [GRASS GIS] #2417: r.profile should report distance in location units
GRASS GIS trac at osgeo.org
Mon Sep 15 08:45:24 PDT 2014
 Reporter:  annakrat            |       Owner:  grass-dev@…
     Type:  enhancement         |      Status:  new
 Priority:  normal              |   Milestone:  7.1.0
Component:  Projections/Datums  |     Version:  svn-trunk
 Keywords:  r.profile, units    |    Platform:  All
      Cpu:  Unspecified         |
Comment(by annakrat):
 Replying to [comment:1 mlennert]:
 > Replying to [ticket:2417 annakrat]:
 > > r.profile reports the length in meters no matter which units the
 current location uses. It would be better if it could report it in the
 current units.
 > The attached patch is a very simple attempt to use location units. I
 don't have time right now to revert the GUI profile tool changes to check
 whether this solves the problem, but at least with this patch distances
 are in location units.
 Thanks for looking into this. The patch seems to work. I got confused from
 the handling of units in the library which is completely weird, and I
 thought the conversion is not working properly but it's fortunately
 computed correctly. I improved the patch. The only problem is the name of
 the units which is in case of Foot_US not recognized and
 `G_database_unit_name` gives just ''unit''. As a result, r.profile now
 prints something like this
 Output Format:
 [Along Track Dist. (units)] [Elevation]
 Approx. transect length [205.092833] units
 but this is a different problem.
 > The question is whether this should be the default behaviour of
 r.profile, or whether this should be only activated when a flag is set.
 In my opinion, in most cases you want the current units. If you think the
 flag would be useful, it should switch to meters and by default (unset
 flag) use current units. Anyone has any opinion on adding this flag?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2417#comment:2>
