[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Mon Sep 15 20:24:23 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
Similarly, G7:r.ros uses `output` which is in fact used as `basename`:
output=name [required]
Prefix for output raster maps (.base, .max, .maxdir, .spotdist)
G7:r.spread is not even taking advantage of that, so the change should be
localized to `r.ros`:
max=string [required]
Raster map containing maximal ROS (cm/min)
dir=string [required]
Raster map containing directions of maximal ROS (degree)
base=string [required]
Raster map containing base ROS (cm/min)
spot_dist=string
Raster map containing maximal spotting distance (m, required with -s)
The fix in this case is: use different options for each map. What about
the names? `base_ros` or `ros_base`? Or no `ros` since the module name is
already `r.ros`? But what about `r.spread`, should this be the same? Maybe
we can use what is used in `r.spread` to make just few changes.
As [http://osgeo-org.1560.x6.nabble.com/Fwd-QGIS-Processing-amp-GRASS-
td5155460.html noted by MarkusN] QGIS Processing has problems with the
current solution:
> r.ros (maybe others): the output in this GRASS module is just a
> prefix for 3/4 output maps with an hardcoded name. Processing does not
> actually support such case.
I hope that the multiple output used by many (e.g. `r.neighbors`) and
suggested for `r.texture` is actually helps QGIS Processing (and others).
Explicit options are of course the safest way.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:13>
