[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
trac at osgeo.org
Mon Sep 15 20:31:24 PDT 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: standardized options | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
Thinking about that more, `r.texture` and actually also `r.neighbors` can
have just number of options for single raster map which would be named
`average`, `sum`, ... This completely avoids the need for multiple
input/output or basename. This approach also removes the need for option
specifying what needs to be computed (BTW, if applied to `r.ros` we can
remove the `-s` flag).
I guess that `r.neighbors` is quite challenging for QGIS Processing and
other wrappers since the output type for each map can be different and
there is [http://grass.osgeo.org/grass71/manuals/r.neighbors.html
#propagation-of-output-precision a table to say how precision is
propagated]. This might be improved a bit when separate options are used
(e.g. `average` is always `float`, `diversity` always `integer`) but
certainly not solved for all and I'm afraid that `FCELL`/`DCELL` makes the
things even more complicated.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:14>
