[GRASS-dev] G7: how to get rid of multiple listing of identical map names?
Glynn Clements
glynn at gclements.plus.com
Tue Sep 16 03:41:12 PDT 2014
Markus Neteler wrote:
> > OTOH, given that it fixes a fairly fundamental bug, it should go into
> > at least one beta prior to any final release.
> So that would be r61840 + r61853 to be backported.
> But how to test it in trunk?
Backport to beta, see if any issues show up.
In terms of constructing test cases, you need a location where the
"... was found in more mapsets" warnings are common.
As a rough guide: clone a mapset, place the clone ahead of the
original in the mapset search path, remove various support files from
the cloned maps, then run commands which try to use those support
files, and check that they aren't "finding" the files from the
original maps.
