[GRASS-dev] G7: how to get rid of multiple listing of identical map names?
Markus Neteler neteler at osgeo.org
Tue Sep 16 07:52:12 PDT 2014
On Tue, Sep 16, 2014 at 12:41 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> > OTOH, given that it fixes a fairly fundamental bug, it should go into
>> > at least one beta prior to any final release.
>> So that would be r61840 + r61853 to be backported.
>> But how to test it in trunk?
> Backport to beta, see if any issues show up.
Done in r61995 (relbr7).
> In terms of constructing test cases, you need a location where the
> "... was found in more mapsets" warnings are common.
> As a rough guide: clone a mapset, place the clone ahead of the
> original in the mapset search path, remove various support files from
> the cloned maps, then run commands which try to use those support
> files, and check that they aren't "finding" the files from the
> original maps.
Thanks - this should be done on various OS.
Markus
