[GRASS-dev] GRASS7.1 experimental temporal framework update
Sören Gebbert soerengebbert at googlemail.com
Tue Sep 16 10:15:19 PDT 2014
Dear all,
JFYI i have updated the temporal framework in grass7.1 trunk (last
commit is r62000) to support distributed temporal databases. The new
default behavior is that sqlite3 based temporal databases will be
created in the current mapset. The temporal framework takes care of
which mapset specific temporal database should be used for data
access. Existing locations with temporal databases should work as
usual.
However, at the moment this works only with sqlite3 databases. Using
several different postgresql database backends is untested. Mixing of
sqlite and postgresql temporal databases in a single location is not
possible.
Some API changes were necessary to implement maspet specific temporal
database management. I did not tested yet the temporal related GUI
modules and code.
Be aware that the temporal framework and the related modules in grass
trunk (7.1 svn version) are highly experimental and should not be used
in production.
The new approach limits the use of SQL where and order statements in
t.list. These statements will be performed for each temporal database,
but not for the output of all databases together.
Best regards
Soeren
