[GRASS-dev] GRASS7.1 experimental temporal framework update
Markus Neteler
neteler at osgeo.org
Tue Sep 16 21:25:58 PDT 2014
Hi Soeren,
On Tue, Sep 16, 2014 at 7:15 PM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Dear all,
> JFYI i have updated the temporal framework in grass7.1 trunk (last
> commit is r62000) to support distributed temporal databases. The new
> default behavior is that sqlite3 based temporal databases will be
> created in the current mapset. The temporal framework takes care of
> which mapset specific temporal database should be used for data
> access. Existing locations with temporal databases should work as
> usual.
Thanks a lot for your efforts!
Markus
