[GRASS-dev] lib/python/pygrass/vector/testsuite/test_doctest.py SIGSEGV
Vaclav Petras
wenzeslaus at gmail.com
Wed Sep 17 06:22:17 PDT 2014
doctest for pygrass.vector are crashing with segmentation fault in
Vect_gen_num_db_links() function.
I'm not sure in which location, perhaps all, perhaps the empty one. All are
reporting missing maps:
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-17-07-00/report_for_nc_spm_08_grass7_nc/lib/python/pygrass/vector/test_doctests/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-17-07-00/report_for_piemonte_utm32_wgs84_grass7_stdmaps/lib/python/pygrass/vector/test_doctests/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-17-07-00/report_for_empty_xy_all/lib/python/pygrass/vector/test_doctests/index.html
Unfortunately, the segfault is not visible in test report, output just
ends. The return code of all -11, does this mean something? Do you know how
to get the info which is available to system crash handler (which contains
"crashed with SIGSEGV", function name and even call stack)?
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140917/401ebbd9/attachment.html>
