[GRASS-dev] vector display clipping
Anna Petrášová
kratochanna at gmail.com
Wed Sep 17 18:40:44 PDT 2014
On Wed, Sep 17, 2014 at 6:56 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Anna Petrášová wrote:
> > > > I still don't understand if the current behavior in 7 is intended
> and if
> > > > so, why no vector clipping is better?
> > > It isn't intended, it's an oversight.
> > I see. So, are you (or anyone else who understands this part of code)
> going
> > to do something about it?
> Try r62026.
thanks a lot!
> This sets the clip region to the destination rectangle by default.
> However, there may be situations where this clips things which
> shouldn't be clipped. E.g. if you're plotting points with
> "d.vect ... icon=...", points near the edge of the map will probably
> have their icons clipped to the bounds of the map.
yes, but that's fine (at least for me)
but, d.rast freezes when I try to zoom to a map with png driver. With cairo
driver, everything works fine.
Anna
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140917/38a56245/attachment.html>
