[GRASS-dev] vector display clipping
Vaclav Petras
wenzeslaus at gmail.com
Wed Sep 17 19:26:57 PDT 2014
On Wed, Sep 17, 2014 at 9:40 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> This sets the clip region to the destination rectangle by default.
>> However, there may be situations where this clips things which
>> shouldn't be clipped. E.g. if you're plotting points with
>> "d.vect ... icon=...", points near the edge of the map will probably
>> have their icons clipped to the bounds of the map.
> yes, but that's fine (at least for me)
For me too. I was thinking about it and the behavior is not what I expect
but it is actually what I want at the end. So it seems to me perfectly
fine. Thanks a lot, Glynn.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140917/5d49b0f9/attachment.html>
